Topic: My headgasket repair..... (Read 1539 times) previous topic - next topic
ill just throw the pics in... not much too describe i guess
im jellouse!! i whanna shop like that!
Got that fox rash again!
-Resident smartass! :ies:
Quote from: Cougar8775
Yes that is a pretty sweet looking shop.:D
thanx.... u can use it if u work on my car for me... finally got it all back together... looks alot better now that i took the time to paint everything and cleaned it all up.... still not running right though... may just have a boost leak... its pouring antifreeze now too... might have blew the seal in the water pump when the headgasket blew too... we'll see
I am looking forward to doing one of those on my '88TC.  I just cleaned the car, waxed it, filled it up and was on the way to get two new tires and it blew.  :mad:
As far as your situation goes, did you use a felpro 1035?  Also, 4 out of 5 stock heads are cracked.  I would check that out if your prob doesn't go away.
Nick
the head is only been the car for about a month.... it has over 40hr of port work and a ranger roller cam.... but i did use the felpro 1035....
