Topic: Front Axle Oil... (Read 1094 times) previous topic - next topic
Front Axle Oil...
The owner`s manual in the Explorer says " to refill the Front axle, use 4x4 gear oil" . I went to the store and a little surprise, there are two, a Sae 140 and a Sae 250. Which is adecuate ?
 I have heard the Rear axle Oil is different, sae 90 i guess...
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Front Axle Oil...
Try this website:
http://www.therangerstation.com/tech_library/index.htm
They have a large amount of information for the Exploder/Ranger.
I do know that the gearbox (Mazda 5-speed) on my truck takes ATF and NOT gear oil. I learned that the hard way.
Front Axle Oil...
stuff other than tractors still uses 90 wgt.. man.
Front Axle Oil...
Not always, many newer post 1990ish vehicals, require as thick as 140W or a 70W140 synthetic.  But yes all the old RWD cars were 90W.  The owners or shop manuel should specify a viscosity, they may infact recomend synthetic.  Check the "fluids" section in the manuel.  Or, as cougarcrager suggested, an explorer website with a FAQ or something.
