Topic: Help Identify turbo (Read 2629 times) previous topic - next topic
Help Identify turbo
Hey guys what turbo is this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ru=http%3A%2F%2Fmotors.search.ebay.com%3A80%2F%3Ffrom%3DR40%26satitle%3D%2B8011793307%26fvi%3D1&item=8011793307&rd=1  I know its a holset but what series? thanks
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Help Identify turbo
looks like a h1c to me
Help Identify turbo
Thats the one you had in your car right? How did you liked it, and In what rpms did it see full boost?
Help Identify turbo
Quote from: 88cat
i liked it, turbo was laggy unless you spray it.if you race it any consider a small kit mandatory 50-75 shot
full boost @4,500 or so  start spooling around 3,000
would not use it on a driver with a stock computer.
Help Identify turbo
What nitrous kit did you have and how much did it cost you? Also do you think it will work on the stock computer for a while before i get a eec tuner?
Help Identify turbo
Quote from: 88cat
the problem with the stock 2.3 computers is the rev limit at around 6,200.
the kit i have is pieced together.
Help Identify turbo
Do you still have your computer tuner? Do you sell it?
Help Identify turbo
Quote from: 88cat
I didn't use one part of the problem with my car.
on the n2o kit  you can usually pick up a used "wet" 5.0 mustang kit for around a couple hundred bucks.
Help Identify turbo
Hey would you happen to have a turbo head in good condition for sale because my engine came with a na 2.3 head. After sending it to machine shop and porting it i finally learn that its a na 2.3 head.:mad:
Help Identify turbo
Quote from: 88cat
i had a ported head sold it locally
I would just pick up some stainless valves for you n/a head and use it. there is no performance differance
Help Identify turbo
But with the NA 2.3 head i will have to much compression like 9.1:0 and I want to run some seroius boost like 30psi.
Help Identify turbo
How will the na 2.3 head work with a holset and 30 psi? I will be running methanol and maybe also nitrous for helping spool the turbo and like how much boost do you guys think i could run with 94 octane and not methanol? The cumbustion chamber will receive some porting also for bigger cc.
Help Identify turbo
Quote from: 88cat
How will the na 2.3 head work with a holset and 30 psi?.
dunno about 30 psi but i do know you can run 22 psi on 93 octane pump gas. with total timing about 25 deg
Quote from: 88cat
I will be running methanol and maybe also nitrous for helping spool the turbo and like how much boost .
methanol injection will reduce detonation. so you can run more boost. remember nitrous will add boost also i seen about 3-4 psi on a 50 shot
Quote from: 88cat
do you guys think i could run with 94 octane and not methanol? .
no, not with 30 psi.  with 20-25 most likely  ive ran 22 on 93 octane
Quote from: 88cat
unshrouding the valves will help increase combustion chamber cc
wich helps reduce compression.
on a side note for 30 psi get some head studs and a cometic head gasket or a copper gasket.  a thicker head gasket will also reduce compression.
also i ran n/a heads on both my cars with no problems. :D
Help Identify turbo
So you were running a na 2.3 head on your 2.3 turbo? What head gasket did you used and did it have any porting? Also how much psi were you running? thanks I really appreciate all your help.
Help Identify turbo
sounds like we're going to learn about the big bang theory here folks
