Topic: Who bought it? (Read 2468 times) previous topic - next topic
Who bought it?
I was talking to a gentleman last night who lives next door to a guy that sold an 88 Turbo Coupe to someone in Manitoba.  The guy who sold it lives in Islip Terrace NY.  The buyer flew down from Manitoba and drove it back.  I remember that the TC had ride control and that was a rare option in 88 from what I understand.  Just wanted to see if anyone knew who it was or if it's even someone on here.
Re: Who bought it?
I wish it was me, but its not. :(
I'll send out a few e-mails to other Manitobans I know (from these message boards) who are into T-bird/Cougars/Mark vii's.
Thats about a 32 hour drive, which I guess is cheeper than shipping it.
Re: Who bought it?
Actually, ajustable ride control was standard on the 87-88 Turbocoupes.
88 TC, Lots of Mods.
Re: Who bought it?
Quote from: Birdman
Thats what I was thinking.
Re: Who bought it?
I know it was standard on the 87, but I thought they changed the setup for it in 88 at some point in the middle of the model year....
Re: Who bought it?
Ride control that still WORKS in this day in age is quite rare.  I'd venture a guess to say that less than 10% of the TC's out there have fully functioning ride control.
Re: Who bought it?
mine works
It's Gumby's fault.
Re: Who bought it?
Quote from: Ifixyawata
I guess I'm in that 10%. :)
Re: Who bought it?
how does the reguler to premium fuel set up work on the tc's
Re: Who bought it?
Quote from: BEARMAX
If you're using high octane fuel, you can run more boost without detonation. So it increases boost and as far as I know advances timing. I'm sure someone else (Chuck, Tom, anyone) can tell you the specifics, but these are the vague advantages I've heard. And yes, it does make a drastic difference.
Re: Who bought it?
Mine 1/2 works.... I have the rears disconnected on firm, so I can set it to auto and loosen up the front for better launches at the strip.
The TC thundergrowl is getting, has fully functional ride controll with replacement Motorcraft struts and shocks. That in my estimation is a 1%-er.
As far as the octane switch it just allows full boost (15psi on the 5 speeds), and probably advances the timing. I've never seen the octane switch does anything on the automatic TC's, as they are limited to 8-9psi boost.
Re: Who bought it?
it limits the boost in 5-speed cars, and pulls some timing out of it, i believe it pulls 2-4 degree's of timing
It's Gumby's fault.
Re: Who bought it?
Quote from: Tbird232ci
so what setting should we be running in with the RR cam and boost controller?
Re: Who bought it?
Quote from: 88turbo
The boost controller pretty much takes over this task anyway. But if the timing change is a truth, I'd leave it on.
Re: Who bought it?
88turbo, i couldnt tell ya, because every setup is differnet, some peoples car will spark knock at 12*, mine doesnt at 14*
try 12*, if it doesnt knock, try 14*, if it doesnt knock, leave it at 14 still
It's Gumby's fault.
