Topic: 86/87 Lincoln LSC rear....... good source for 5 lug? (Read 3286 times) previous topic - next topic
did a lil junkyardin' today, and found about 5 or 6 lincoln lsc's, and one mercury xr7.
would the licoln rear end swap into my 88 tbird? can i use the e-brake cables also? how much wider/narrower is it than mine?
1979 Ford Fairmont
[/B]
Re: 86/87 Lincoln LSC rear....... good source for 5 lug?
I used Mk VII axles and brakes in a TC rear on my Cougar, came out same width as the TC.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: cougarman
mk VII and lsc rears are the same? why not use the mark VII housing, too?
1979 Ford Fairmont
[/B]
'cause my TC housing has 3.73 Trac Loc. :D
LSC is just a model of MK VII. ;)
Does the Mark VII have vented rear disc?
I think that they are solids. Most mustangs are
Quote from: Haystack
no they are 11" vented  same as the svo mustang
Quote from: SLEEPER T-BIRD 87
Yep they are vented!!  ;)  Bigger than the TC ones also. :D
Use the whole rear end, the whole wider track this isn't that much of a big deal as everyone makes it out to be.
Willpower is no match for Horsepower.
Quote from: David
how much wider than the 7.5" rear ends? id like to be able to run some deep dish fr500s, without clearance issues.
1979 Ford Fairmont
[/B]
Quote from: 5ohbird
The SVO/Lincoln stuff is 1/2" wider per side than the TBird/94-98 Mustang stuff, or 1" overall.
Quote from: David
Mark doesn't have quad shock mounts.......
Matt :tg:
Matt :tg:
Quote from: slowfoxbird
Matt :tg:
 Yeah I know, my 7.5 did, the Mark 8.8 didn't.  No biggie if you use good U/LCA.
Where do you get u/lca's that are the correct length?
Matt :tg:
Matt :tg:
