Topic: I got bored... (Read 2524 times) previous topic - next topic
I got bored...
so i spent maybe 45 minutes on my upper intake, i just took some 320 grit, cleaned up the ribs and lettering, threw some red paint in the ford emblem, and did a little more sanding
im eventually going to be swapping out my intakes for a ported set, so i figured what the heck, i like the scheme, so my next one will have much more time invested
It's Gumby's fault.
Re: I got bored...
the color is supposed to be ford blue j/k looks good
Re: I got bored...
i knew someone was going to say that
im sick of blue, you buy a cold air kit, it has blue couplers, you buy anything aluminum thats aftermarket, its blue anodized, you buy some plug wires, theyre blue
i decided that i want to do something with red, car has a red interior, red stripe, so i might as well carry it under the hood
It's Gumby's fault.
Re: I got bored...
I wonder if some good aluminum cleaner would brighten that intake up?
Re: I got bored...
I did mine in blue and I have been planning on polishing the raised portions.  just so you know I had this idea too.
Re: I got bored...
like the red ideal.how about painting the calipers red as well?
Re: I got bored...
Quote from: CougarSE
it probably would, but it would be more work than what i want to do, since im working on possibly getting my spare intake ported, and id redo all the work to that one, if i cant clean it up, im going to spray it with aluminum paint and then polish the faces and paint the Ford oval red like that one
Quote from: 88turbo
well...its not like either of us were the first to do it...i got the idea from someone else, who had the idea from other people...
Quote from: 30thtbird
ive actually been wanting to for a while, i just would rather spend the 10 bucks on gas, or something i need rather than paint right now, the stuff i used i had laying around, i think the red would look badass behind my black wheels
It's Gumby's fault.
Re: I got bored...
Quote from: Tbird232ci
very true I like the idea.. did you brush it in and sand the high spots?  thats how I did mine  with the engine enamel
Re: I got bored...
i sanded most of the casting marks off, then i brushed it on, and sanded it, since the surface was pretty smooth, it came off nice and easy
It's Gumby's fault.
Re: I got bored...
Looks good. Nothing wrong with the red.
