Topic: need help asap. timing. sparkplug (Read 978 times) previous topic - next topic
1990 Mercury Cougar LS V6 3.8 (non superchanger)
 i just change the intion pole and cap, rotor, plugs, wire. put them back on and enginellike they were but the wouldn't kick over?  :mad:
 could some show a pick on how the plugs go on the cap and the placement of the intion pole??
lookd on goolge. but nothing  :bs:
 and i cheap way of fixing this too
Re: need help asap. timing. sparkplug
For your 1990 MERCURY COUGAR: firing order 1-4-2-5-3-6
from front of vehicle- 1 2 3
                              4 5 6
distributer rotates counterclockwise.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I had a problem with mine that sounds similar to this... I do not know how the cap and rotor are setup on yours. I know they are different between 83 and 88. So this might not be of help. But I had the rotor in backwards or upsidedown, I forget now, but mine wouldn't start (go figure  :hick: ). So my guess is it is probably just something little like that, double check back over it all.
Frank M
1985.5 SVO
thanks guys :cheers: . i got it :banana: working :welder:. i took dig pix off it. but that was no help. even the whiteout i put down was uless to. LOL
I answered with pictures and everything in your other thred.
