Topic: Squeak from trans tailstock (Read 1681 times) previous topic - next topic
I've got an '87 AOD that has started squeaking at the very back of the transmission.  It sounds like "chirpchirpchirpchirp...".  I jacked the car up because I thought it was a u-joint but it's not.  I can move the trans yoke up and down a little - should I be able to do this at all?  It isn't leaking at all.  Would this be a bad bearing?  Can the tailstock come off with the trans still in the car?  Will I have to drain the fluid first or is there another seal (I'm assuming there is) on the splined shaft in the tranny?  Lastly, if this is a bad bearing,  is it something I can change at home or should I take my tailstock to a shop with a press?
Thanks
 :canada:
Re: Squeak from trans tailstock
anybody?
