Topic: Which mod should be next? (Read 1239 times) previous topic - next topic
Im replacing my motor because yest. I started it and it was ticking very loud and I looked at the oil gauge no presure. checked oil there was plenty. so I was wondering with my speed density set up which would yield more power for the buck. the venom chip or a cobra intake top and bottom.
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Re: Which mod should be next?
I'd go with the Cobra Intake of the two. Then some kinda head mod...
no chips.. I run my combo with the stock computer and ignition system and it runs great
How about you buy an explorer or cobra intake and get a pair of good heads and do it all at once..
Not to get off the topic but,speeking of explorer intakes, I bought my 88 bird and the guy said he swapped out the factory intake with the explorer upper and lower. i have the factory intake as well. What is the visual difference, cause they look the same to me?
the explorer intake that you want looks like the cobra intake.
