Topic: Oops, I did it again. I bought a new car. (1986 Ford LTD wagon) (Read 69956 times) previous topic - next topic
Re: Oops, I did it again. I bought a new car. (1986 Ford LTD wagon)
Reply #45
OK, back to the wiring.
Seeing as I got pretty much most of the bulk of the wiring to the bulkhead connector from the engine bay, I need to get in the car and sort out the wiring from inside or the rear of the car to the bulkhead connector.
The throttle pedal and the DataLink Connector are at the dash, but the rest (Fuel and emissions) is at the rear. That means I needed to first tackle the nasty bit of removing the interior and headliner, as I knew it was all going to be gross.
I started to get the headliner out first, because I knew it was going to make a mess.
I was right.
So much mouse poop. :yuck:
I'll be able to reuse the front board, but the rear one I'll probably have to make a replacement out of ABS sheet. The mouse nests were worse back there.
After that, I pulled out the rest of the trunk area panels and the rear seat.
It's amazing how much dust/dirt is on EVERYTHING inside this car behind all of the panels. Gonna take some time just to clean that all up.
I did unfortunately find some soft spots in the floor under the rear seat base.
Kind of not surprised, as there was water ingress due to door strikers not having bushings on them.  Should be an easy repair, though.
Both lower rear quarter panel areas behind the rear wheels was also full of mouse house stuff. No corrosion, though.
I took all of this out, as I needed to trace the stock FP wiring back and de what I needed to do for the new stuff.
The original FP relay is on the PS rear, and the inertial switch is on the DS rear. This thing also had the dual FP set-up, which is getting replaced with one.
Going to remove all of the wiring to the front pump and rework the rest for the new pump set-up.
Reply #46
Gross and then some. Unfortunately I can smell those photos.
Otherwise good stuff.  For 29 locations that bulkhead connector is fairly compact. Duetsch connectors?
Reply #47
Yeah, it's a Deutsch HP20 series connector. It's got 12, 16, and 20 sized terminals. which worked out great for what I needed.
Been a busy week getting back to work FT after the surgery, so limited progress other than researching switching some things around on FP control/power and making a decision on what needs to be done for working AC. More details on all of that when I get some more interior wiring done.
Reply #48
OK, finally got the parts I was waiting on.
That's a FPDM (Fuel Pump Driver Module) from an '02 Mustang, but pretty standard for many of the '99-04 Fords with the returnless fuel systems.
Originally, I was going to try and use the '11 FPCM (Fuel Pump Control Module), but was going to have to find a way to spoof the signal from the RCM (Restraints Control Module). After '05, the cars did away with the inertia switch and used impact sensors over CANBUS to feed the RCM and that would be used to shut down the fuel system in case of an issue. I was going to feed a 10Hz square wave signal to the FPCM, which is supposed to be the "all clear" to allow pump function. That still may work, but I figured there had to be a way to do things without that.
Not having spent much, if any time with Mustangs past '00-'01, I never even knew about all of this.
Anyway, the car with the FPDM also used an inertia switch, to interrupt power to the fuel system in case of an crash, and still modulated the fuel pressure based on the need.
I'm replacing the earlier "white button" inertia switch with the later "red button" one, which is rated to carry the full current load for the fuel system, instead of just a control voltage for the the old FP relay.
This was the last of the stuff I needed to get my fuel system stuff wired up and be able to start doing power-up and systems checks.
I still have a good day of getting things wired up to the bulkhead connector to do these tests, but I finally have pieces in hand to hopefully make that work.
Reply #49
So, I got things to the point where I'm able to do this.
Got the PATS delete tune flashed and no smoke escaped from the wiring harnesses as I've put together, so I consider that a win.
Only have the bare essentials together to power things up, but a lot of needed things aren't wired yet.
Lots of DTCs and no crank, but the fuel pump is "priming" as it's running full voltage, but seeing as there is no fuel in the system to pressurize, it's not going to see pressure and shut the pump down. It appears that the earlier FDMP is working as it should, and I maybe don't need to deal with the FPCM.
Reply #50
Working when I can.
Switched to using an HP Tuner instead of the SCT, as I wanted more control over things. Have that all set up and moving forward.
Otherwise, just been basically chasing down some trouble codes and sorting out the bits of wiring I hadn't done at the bulkhead connector yet.
One of the things I needed to do was sort out the fuel pump and tank, and get it close-ish to being mounted. Before mounting a tank, I needed to prep the floorpan, as I was going to seal things up a bit, because this car was going to get driven on the regular.
I grabbed a case of this stuff
It's a wax-based encapsulator/sealer.
I'll be doing the entire underside of the car with it, but just got the rear cleaned up so far.
The closer stuff was still a bit wet when the pic was taken, but you can see that it dries to kind of a satin finish.
Next was to get the new fuel pump installed.
I'm using a Deatschwerks DW200 (similar to a Walbro 255hp), that I needed to modify the hanger to get it mounted.
Before finalizing things, I wanted to check to make sure things were in the proper spots. (You can see the test spacer I made up in this shot (green))
When I was happy with how it all was, I reprinted my spacer out of some PEKK material, which is gasoline resistant. Modded the pick-up tube and installed the correct submersible fuel hose.
Next project is to drop the valve body out of the 6R80 to replace a faulty lead frame (Shift position sensor), as a few of the DTCs are pointing that direction.
