Topic: I may look into making some poly motor mounts for the 86-88 3.8/5.0's.... (Read 17670 times) previous topic - next topic
Reply #90
Count me in for a set as well.  Did we come to a conclusion on finish color?
Reply #91
I'm pretty sure these are going to be zinc plated.
What I'm going to do when I'm ready to do these is basically say I'm going to do "X" number of sets, and place my laser parts order at that time.  It won't be some 20-30 set order either.  I just can't work the larger batches at the moment.
I'm hoping to have the new isolators worked out by then as well and have switched to the stainless sleeves, but we'll see.
Reply #92
I am going to need a set but after Thanksgiving is fine.I am working a deal on my motor and tranny combo now.I will need them late December early Jan for sure though.
 Thanks,
  Chris
Reply #93
Well, I'm trying to decide if I want to do them the middle/end of Dec (at least get the orders taken and material ordered, etc).
I'm trying to shorten the turn around time on them.
Reply #94
Whatevers best for you Chuck.I think the MN12 mounts I have will work for now and it is sure alot easier to change the mounts on a fox then an MN12 or TurboCoupe,lol.
 Thanks,
  Chris
Reply #95
OK.  Just a reminder bump for those who were interested.
I'll most likely be running a small batch of 10-12 sets of these.  I'll be taking orders and such just after the first of the year.
Reply #96
Cool. I'm in
Reply #97
Same here, count me for a set.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Reply #98
I'm in!! :D :bowdown:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #99
I'm in...
Reply #101
Put me down for a set!
Reply #102
i wish i could use them there so purdy....
~John~
Reply #103
I'm in for a set!:D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Reply #104
I will need a set, but as long as you will be making another batch eventually, I can wait if someone needs them for this run.
