Topic: engine running too cool *solved- installed non failsafe tstat (Read 23617 times) previous topic - next topic
Reply #75
I have a non-failsafe tstat lying in the back seat now.  hope to change soon.
Reply #76
Hopefully it will fix your problem. Things like that drive me nuts till I figure them out.
I gotta figure out why my trip computer is reading goofy. I think it might be electrical or a bad unit. Maybe a vacuum leak to my recently replace map sensor? I drove 100 miles with the av mpg sitting at 11.1 but I could only get 5 gallons in my tank.
Reply #77
Quote from: jcassity;453810
Let us know how it goes.
Reply #78
its going to happen tomorrow,,, cause today im not going outside for anything
Reply #79
Just a FYI, yesterday it was approx 28* so I started the truck to get some heat and when the temp gauge was near the point I know the stat opens, I kicked the blower on high(which I rarely ever do)... Well temp started falling, leveled off just below the O in normal and set there, not going any higher... I felt top of radiator at inlet, cold... The heater was cooling engine at idle... Once I started driving, temp came on up to middle of NORMAL where it generally runs...
Sooo, the radiator doesn't need to provide much cooling when temps are below freezing(maybe none at all if below zero)...
Reply #80
FIXED!!!!!!!!!!!
finally
Reply #81
Sweet.
Reply #82
Quote from: jcassity;453942
FIXED!!!!!!!!!!!
finally
Awesome. Now no more fail-safe thermostats ;)
Reply #83
Quote from: thunderjet302;453967
yes sir,, wont do that again..
I almost posted a thread "car putting out too much heat"
its doing very well and I felt like a normal human being driving up to PA today.
Reply #84
Glad to hear you're warm again, you may get better fuel milage as well...
Reply #85
Yes gas mileage went back to normal again as you can see in the picture and the odometer just turned 300,000
 I am missing about 20,000 miles from an intermittent instrument cluster flex print but the odometer says 300,000 now
 I should have about 320 but who knows
Reply #86
Wow what a py picture
Reply #87
I miss the full digitl dash.
Reply #88
Yeah I like it
 It's 26 miles per gallon
Reply #89
I haven't been able to get this cougar over 22 highway for some reason. It does 19 city. Doesn't seem to care where the timing is at or anything. I think I may have figured it out now though.
I have verified my trip computer is not reading even close to accurately. I filled my tank and drove 500 miles. It said 27 gallons used, could only put 17 gallons back in. That adds up to 29mpg roughly. It started randomly dropping from a fairly regular reading of 22mpg @ 75mph down to 6 mpg randomly and popping back and forth.
Gonna go over my spliced wires for the trip computer. Pretty sure its gonna be the fuel feed wire one since my trip computer mileage always matches my odometer trip. Either that or maybe it has something to do with the $40 auto zone map sensor I put in it. I might just swap the one off my dads 460 for a few weeks to see if there is any difference.
