Topic: New Thunderbird owner (Read 1785 times) previous topic - next topic
Hi
I have just bought a 1986 Thunderbird 5.0 and i`m new to fox-body fords and i will probably need some advice on this car. Hoping you people is the right ones.
I will post some pics when i get it home
Thor
Re: New Thunderbird owner
well yes I would say that we ARE the right ones. There are lots of guys here that know more about these cars then the people that made them. This is definately the right place to be. Also make sure that you check out http://www.coolcats.net
Yep. already in my favorites hehe. Some usefull tech tips there
Thor
check out the HO conversions. Gain ya an easy 75 hp. I am going it with a car that I bought for $110(86 cougar with the 5.0) and a wrecked mustang that I am buying off of a freind for $300.
I look forward to seeing your pictures.  You are deffinately in the right place.  When I joined I knew nothing and the generosity of the folks around here has given me the ability to do most anything with my car.  Jason.
Welcome aboard! :)
thanks you folks.  Cant wait to get my car and start on it.
I see that i must do something with the power but i live in norway and H.O parts is rather hard to find here. Can i go with lets say edelbrock and new cam and a single 3" exhaust. and some ported heads of a 79 302?
I know this might bee in the wrong forum but anyhow
ThunderThor
welcome man...I also own a '86 302 T-bird
Quote from: woody76
ThunderThor
If your planing on a cam that had more lift/duration than the HO cam, Only the Trick Flow Twisted Wedge heads will work on a SO shortblock that has the flat top pistons. I've been using a set with the small Trick Flow cam for almost six years now. You can run the ported heads you mentioned, just have to stay with a mildish cam...
