Topic: [URL=http://s28.photobucket.com/user/tfalconier/media/D43C9793-A1EE-4A40-9B36-5431696 (Read 1555 times) previous topic - next topic
Over the years i have had to fix issues because of parts that are GARBAGE. And Stat gaskets fit this scenario. The gasket makers slot the bolt holes and that makes them leak quite nicely. So what to do??? MAKE YOUR OWN. This housing is from a CHEVY and it leaked when installed by the owner. You can see the silicone smeared all over it and that is not GOOD!! Even with the silicone the housing was destined to leak. So here is the cure,no slots no leaks and absolutely no silicone ever!! SIMPLE
If you guys think Ford Stat housings are hard to change try this VETTE. WOW what a pain in the #$%
While i was changing the stat i noticed the fuel pressure regulator nipple was busted off. So i replaced it. The customer could not understand why the car ran like garbage. Compounded with the timing retarded 20* after i finished it ran like a vette should run. Naturally the owner stripped the upper plenum bolts. I had to repair them with oversize bolts. Quite common with people that do not know how to install this intake.
I don't know why people use silicone on every  gasket. If you need to hold a gasket in place use high tack: http://www.permatex.com/products-2/product-categories/gasketing/gasket-sealants/permatex--high-tack--gasket-sealant-detail It holds the gasket in place when you assemble the parts and doesn't leak out every where.
I think I have that same ratchet lurking in the on board tool box in my truck
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
I still think that intake looks cool.  Tom, where do you buy sheets of that gasket material?
Mike
