Topic: Wireing Diagrams Needed. (Read 1124 times) previous topic - next topic
I pulled the over head console out of my Mark VII and wanted to install it in my Cougar. I have the plugs and all pulled but can't find a wireing diagram anywhere for this thing.
It has temp, compass, tail light out, head light out, check engine, check suspention, and the moon roof switch in it.
Re: Wireing Diagrams Needed.
Here you go. Good luck - it is FAR from a plug and play item! I had considered this install myself (as well as the Linc tripminder) but decided against it due to the extensive wiring required. Just to get the lamp out warning working you would have to rewire all of the lights in your car if it didn't originally have the lamp out warning system. Instead, I installed a Crown Vic tripminder and a Explorer overhead console with temp/compass. There are threads in this forum detailing both installs.
Thank You,
I have been looking everywhere for it. The local libray said they don't have it becasue the vehicle was too old.
Look even the libray says are cars are too old.
I have an 88 XR7 so I already have the system sentry on it. So I don't need to work about that.
