Topic: Valve cover vent tube...... (Read 10038 times) previous topic - next topic
Reply #60
Don't run a PVC with a valve cover breather if you run a breather in the valve cover run a breather on the back of the intake
This is what I did
I was filling a steeda oil separator in a day
Reply #62
Quote from: STANG8U;408663
This is what I did
WOW i have reservations about that. Can you elaborate!!
Reply #63
On what?
Reply #64
The above quote,  Or do you mean from the valve cover to the intake??
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #65
I ran a breather on the valve cover with the PVC hooked up for a long time one day a buddy pointed out that I'm pulling in un metered air I also had a large oil in the intake problem so I put a breather on the rear of the intake the pistons coming down push the pressure out
One day ill use a vacuume pump
Reply #66
Stang8u, I think your pregnant, you missed a couple periods:mullet:
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Reply #67
.....I really don't have room for a filter on the back. I have a/c lines there. I need the following...A way to run the valve covers as cleanly as possible and as simply as possible with out oil catch cans, vacuum pumps, and the like. An oil fill cap of some kind is easy. But the vent line.........
Reply #68
Quote from: 1BadBird;408687
Nope just bloted with beer lol
I'm a better mechanic than school teacher
Reply #69
All's good :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Reply #70
Quote from: STANG8U;408683
This effectively disables the PCV system. I don't think that's what Vinnie is looking to do.
Reply #71
Prob not this is my race car
But if you run a aftermarket intake it will pull a ton of oil I was filling a oil separator in one trip
Just pointing out a valve cover breather pulls un meatered air
It's so little it's not a big deal but it dose
Reply #72
That unmetered air has already been accounted for in the ECU's programming.
Reply #73
Like I said its not that big of a problem but it dose pull it
I did this because I pulled a lot of oil
Just a opinion you won't pull so much with a stock ish motor
Reply #74
I hear ya. I just don't want to over complicate things for Vinnie's sake. 8 pages explaining something as simple as a PCV system?:dunno:
