Topic: Need help ABS Buzzing. Brake light on, ABS Light not on. 88 TC (Read 2315 times) previous topic - next topic
ABS Whining, Will not stop buzzing, even with key off.
Have to disconnect battery to stop it, doesn't matter how long you have the battery unplugged for, once you hook it back up, Buzzzzzzzzzzzzz...
1988 Thunderbird Turbo Coupe - Black - 5 Speed - 181k Miles
1989 Chrysler LeBaron Conv - Silver - Auto - 24k Miles
1993 Thunderbird LX 5.0 HO - Silver - Auto - 72k Miles
I'm assuming relay is stuck open?
Stuck closed I'd say. But yes pull the relay out at the rear of the engine bay near the wiper motor and see if it stops buzzing. Those things are in there tight, so be careful you don't break something or bang your knuckles when it lets go!
Well. I was fiddling with the relay and heard a loud click, and the ABS motor turned off.
If it happens again, I'll just take the relay from my parts car.
click on my diy link and go to the ABS section , i tried to do up a schematic illustrated troubleshooting step by step within the drawing to help.
hope its just the relay, there is probably a diode in there and if so its open / shorted.
I ditched the ABS and installed power brakes, problem solved!
Quote from: 88turbo;402546
i ditched the abs and installed power brakes, problem solved!
++++++++++++++++++ 10000%  ditch it asap!!!
I'm gonna be ditching mine sometime here. It doesn't work anyways so no big loss for me!!!
