Topic: correct clutch cable route (Read 2211 times) previous topic - next topic
ook, if you all remember about 3 weeks ago or so I had to do a new clutch cable. Well I was under there looking to make shure everything was okay and nothing was wrong... Well apparently I ran the clutch cable along the wrong route to the transmition, and it is starting to wear the rubber away cuz it is slightly touching the stearing colomn. Can somebody with the same setup (not the hydrolic) show me some pictures of the route it is supposed to go? I see a few possible routes, but I want it in the right one... I believe that 84-86 is the same also... thanks for everything....
Frank M.
1985.5 SVO
Re: correct clutch cable route
or at least tell me the best route for it not to rub...
1985.5 SVO
Well, I'm fighting a cold and feeling like shiznit, but I went out to see how mine was run.
It comes out of the firewall and runs forward, kind of near the brake mastercylinder.  Then it loops back and actually passes through the K-member just below the motor mount frmo the front.  Then it continues onto the bell-housing.
do you still need pics?  i have a drive train shop manual.
I went and rerouted it yesterday to what I believed followed the directions. but if you have pictures and have the time, thanx.... just to double check....
1985.5 SVO
btw, thanks guys for the help!!
1985.5 SVO
