Topic: that surprised me, 1cu ft= 7.49gal (Read 1675 times) previous topic - next topic
i was designing out a 250kw generator project up in bennington vt and had to calculate the fuel consumption of this Detroit Diesel so i could tell the fuel tank maker how big.
I ended up having to flip to through my ugly's manual to figure out how many liquid gallons there are to one cubic foot.  This genset will use about 27gal/hr and it needs to be 72hr rated.
come to find 7.5liquid gal =  1 cu foot.
i would have never guessed.
It's hard to believe,but it's right.
Hmm. That IS a bit surprising.
~John~
Wow 27gl/hr?? that's a lot of fuel.  The last truck I drove pulling a step-deck and grossing 80k, got right around 5.5 mpg w/ 500hp Detroit 60 series turning 1750 rpm at 65mph. That figures at around 11.81 gl/hr. Is that engine a v12?? Just curious.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
250kW would take a lot of energy to make. That's a quarter of a megawatt. I can power my entire house with my 6kW generator if I turn off the electric heat and use the electric range sparingly (IE one burner at a time)...
750 Watts is 1 HP if memory serves me.
Just about, yes.
~John~
it was just not fitting into my imagination because all i could think about was........... my 5gal can of gas "cant" fill up a 12''x12''x12'' cube
Quote from: Thunder Chicken;383383
thats right,, you'll never see more than 25A in typical residential service.  we all have a lot of head room.
now in my case, that changes when that 18kva tankless water heater kicks on coupled wth all other linear and non linear loads.
Quote from: TOM Renzo;383389
and approx 2.4hp gas engine to 1hp electric motor
