Topic: Last tool you will ever need to buy!!! (Read 1565 times) previous topic - next topic
Re: Last tool you will ever need to buy!!!
that rocks!
ive used them on many cars...havnt used one on my own yet...
used one of those in conjunction woth jb weld to fix my exhaust leak
how well does jbweld hold up? theres 3 holes in my hatch where the blue oval used to be...could it fill that and also could it fill in like nickle sized holes if i were to take off my spoiler to put on another one?
You cannot have
With ANY negative feedback
Less than 500 positive feedback
More than 600 positive feedback
yeah I dont know about that
they could prolly sell it as a jimmy aswell
Quote from: Bane
if you dont have access to a welder i'd fill the small holes with a pop rivet or a screw, hammer it in so its level with the surface of the body then cover it with a bit of bondo or spot putty depending on how close it is. for the larger holes you either have to weld then up, pop rivet in some metal, or fiberglass over them, I havnt used jb weld for bodywork... yet! i'm gonna use it on my hood as soon as I get around to it
maybe Ill try the fiberglass, still have some stuff layin around from when I took the hood scoop off my car.
should i inset the fiberglass a lil bit into the holes then sand everything else smooth then body fill it all? or just keep the fiberglass cloth flat
Q: i currently live in the galapagos islands. would it be possible for one of your engineers to fly out here for a couple of weeks and draw up a design for...more
 May-31-05
 A: Absolutely. In fact, we value our customers to the extent that I will personally volunteer for this task and charge expenses ONLY! How's that for...more
 Q: Awesome product guys. What is the load limit of your product? I need extra carrying ability for the oversized rad on my big block vespa!
 May-31-05
 A: Standard Rad-Bracket has been tested to a tensile load of 8000 lbs! Heavy-duty Rad-Bracket has been tested at twice that limit! Once you have used...more
 Q: Since I have both vintage puppiesanese and Vintage British bikes I was wondereing if the RAD-BRACKET is available in both metric and witworth?
 May-31-05
 A: Make sure you state your application when ordering. One of our sales engineers will set you up.
 Q: Is it available in stainless? Regards, L'Scott
 May-31-05
 A: We are still working on a stainless version with the right mechanical properties to meet our strict standards. You will find, however, that the corrosion...more
 Q: This is an incredible deal at $9.99 .. I've seen these advertised for much more elsewhere !!. Is there a catch ?
 May-31-05
 A: No catch. In fact, if you order now, we'll throw in a roll of Muqutada al-Solder for your electrical needs. It melts under pressure!
I just wish I had as much time as this person :giggle:
They work good as welding rods too!
2 88 TC's (1 is the 2.3t race car, other v8 maybe?)
06 dodge dakota 4.7 v8
79 chevy k-10, built 350/turbo 350
Diverse ain't I?
AMSOIL Dealer
