Topic: Speedo gear (Read 2023 times) previous topic - next topic
Speedo gear
OK tired of my speedo being 8mph fast, I have I believe a 19tooth in my c4 trans with 3.73 gears. Any one know what the correct is?
Speedo gear
I'm running a Black 21 tooth with a 225/ 60/ 16  W/ 3.73  It runs close enough for me +/- mph there's a chart motorsports putout. Or give me your tire size and tranny I can make a call and get back to you
Speedo gear
Im not sure, but mine isnt reading right with my new gear.  I may be able to sell it to you cheap if it is what you need.
Mike
Speedo gear
Thanks thewestie, I know the chart your talking about in the back of the orange motorsport book. Used to have one but threw it out and got a new book thinking it would be in there, but of course it wasn't.
Speedo gear
Btw I haven't got a chance to look at my car (we have a long distance relationship) but its stock tire size.
Speedo gear
Rule o
Speedo gear
Quote from: TOM Renzo;371931
Rule of thumb
A method of determining the north pole of an electromagnet.
I think I learned that in a H.S physics class. It's interesting how that became such a wide spread saying.
Speedo gear
Yes i
Speedo gear
Yeah, I think you wrapped your right hand around the coil so your fingers pointed in the direction of current flow. Then your thumb pointed to the north pole.
Speedo gear
Don't forget that tire diameter has a role in how the speedo reads as well....
Speedo gear
Quote from: V8Demon;372333
Paul your pm box is full...:poke:
Speedo gear
Quote from: mercury-man;372334
fixed....
