Topic: Does are search really work? (Read 1213 times) previous topic - next topic
It might be me.
Seems when I search it returns the same results no matter what, I just thought it was picking up people sigs for key words.
worked for me the other day when i was looking for fordguy's build thread on his TC
I always use the advanced search. and pick the "and earlier" option... doesn't seem to work for me if I don't select that
Quote from: daminc;370500
I'll give that a try.
We're missing roughly 4 years worth of threads. I think they got lost when the board was down due to the server issue. There are old results, like from 05/06 and new results from 2010/11, but not many in between.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
It works; it just has a memory lapse. :hick:
Matt
I've always had the most success from using the Advanced Search. From there, you can select sub-forums and title-only searches, which weeds out the stuff you're not looking for.
I couldn't even find all post by me,when I click on my name, It's probably me. Lack of patience lately.
Sometimes you are better off just using Google to search forums. Go to Google and type
          site:foxtbirdcougarforums.com: headlights
Just replace headlights with whatever you are searching for.
...and there was light!
