Topic: Some turbo, some 5.0 ho parts (Read 695 times) previous topic - next topic
FORD 2.3 TURBO PARTS:
D PORT CYLINDER HEAD NICE-$150
E-6 TURBO MANIFOLD-$50
LOWER INTAKE-$30
UPPER INTAKE-$25
STOCK THROTTLE BODY-$20
RANGER ROLLER CAM CONVERSION-$65
MISC SENSORS AND FITTINGS- ASK -$5 EACH
V BELT PULLEYS-$30
WORLD CLASS T5 TRANS-$200
CABLE ACTUATED BELL HOUSING-$50
5 SPEED DRIVE SHAFT-$35
T BIRD TC DUAL LERS AND TAIL PIPES- NEAR NEW-$50
FOX MUSTANG 5.0 PARTS:
CLUTCH PEDAL SET UP WITH ALLOY CABLE ARM-$65
5.0 T5 BELL HOUSING AND FORK-$45
CLUTCH CABLE-$20
E7 HEADS-$30
5.0 OIL PAN-$25
5.0 HO BLOCK-$50
5.0 HO INTAKE UPPER AND LOWER-$25
5.0 FULE RAIL AND HO INJECTORS-$30
5.0 DISTRIBUTOR-$20
5.0 TIMING COVER-$40
5.0 ACC BRACKETS ALL-$30
5.0 CRANK UNDERDRIVE PULLEY-$10
5.0 STOCK ALLOY VALVE COVERS-$25
88 GT 11" FRT BRAKE SET UP-$75
everything located in forest hill md, big parts, engine block, rear etc... local pick up only, all prices are OBO. thousands of other parts in stock, email or pm with needs. more to be listed soon.
John
I know its a big ask, but would you be interested in posting the Accessory brackets for the 5.0 to australia?
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
You know what I need.
John, too bad we weren't closer...I'd sure take that T5 off your hands.
yes pm me your shipping info to Aus and I'll check the shipping cost for you
John
