Topic: Finally I have smoke! (Read 4383 times) previous topic - next topic
This build has almost ended my interest in cars altogether. Today almost made it worthwhile. It was a nice surprise when everything (almost) came together.
Earlier in the day it couldn't peel the skin off tapioca. I regapped the plugs at 0.35 and took it for another spin. I punched it not expecting much of anything and saw smoke in my rearview. Success.
I did one final run from a 5mph roll. I kept my foot in it this time and got lots more smoke.
Now I just got to tune it up (plugs were covered in black carbon, rich im guessing) ,set the timing and put in the TC rear with 3.73's.
another view:
why is there only 1 mark????  and a skinny mark at that.
John
Quote from: hcor;357109
It's probably because it was just about to take off the ground and couldn't quite make it all the way.
1987 Thunderbird Sport (soon to be GT edition) - In shop getting new paint job and interior work. (put on hold as of 11/2/2010, Resumed and going at it slowly its hard to be poor nowadays...)
One wheel peel....LOL. Hey, once you get the 3.73's in, you'll really feel a difference. Glad you're making some progress. Now, a pic of the car doing it.
Yeah its a thin mark but after 4 years of waiting that's enough for me. Its got the stock 2.73 rear with no limited slip and sport wheels/tires. Now if I can get the TC rear in it before I either sell it or the next 4 years pass who knows.
Forgive my ignorance here, but what is the benefit of gapping the plugs to .35 instead of .50 (assuming you have a v8)?
FOXLESS!!
1994 Lincoln Mark VIII
It was running really rough. I had the same problem when the SO engine was still in the car. I tightened the gap in the plugs and voila. I don't know why other than maybe a problem with an engine ground wire?? I'm guessing there's not enough juice to jump the gap at .50 even though I replaced the coil, wires, plugs and cap. Its just another issue I've got to sort out. Oh yeah, its just an HO engine out of a 93 I believe.
I can smoke my tires with what I believe is a stock S.O.(firing order indicates S.O.).  Then again I haven't looked for casting numbers on the heads or looked into the rear end to see if anything was changed though.  But after years of having weak fwd cars that could only break the tires loose on wet roads or while turning it is quite a change.  Don't give up man, I gave up on my first car after swapping engines only to find out the issue was an easy $60 fix.
Yeah its been a long road. Its pretty hard to get motivated to do anything anymore but I'm sure there plenty of guys here in the same boat. Now I'm inheriting my parent's car and have to make a decision to keep her or sell. Parent's car = very tired GN
What did you do to get the peg-leg skidmark?
I just floored it from a 5mph roll. I really want to know what the difference will be like with the 3.73s. Maybe the higher ratio will still have me spin'em even with the limited slip. And yes I plan to put wider tires on it. I knew the car would be sitting for a while and it made no sense to buy new tires and let them rot.
You sure you didnt slam on the brakes with a donut on the front wheel trying to fool us???  J/K-watch that mercedes  next time you decide to do a smoke show!!. Put that rear in quick-Night and day difference with 3.73's-good luck with the install.
Thanks for the encouragement. I'm starting to see light at the end of the tunnel and its getting fun again. And that's the first time I saw that Mercedes on my block. The cat was just marking its territory that's all.
With the 3.73 rear, it adds no power at all, but, it allows it to get to the ground, and you'll swear you added 50 horsepower or more. That's why gears should always be the first mod done to our cars.
Feels like 50 horses?.....guess I know what I'm trying this weekend....assuming the wife doesn't already have plans for me :)
