Topic: Best way to remove body side molding (Read 1981 times) previous topic - next topic
I need to remove the body side molding off my sport and want to reuse it, How do I do it without bending it up ? Whats the best way to reattach it, 3M two sided tape?
 I tried the search engine but this new one doesn't work near as well as the old one.
Thanks
Leon
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
Don't worry about bending the metal backing on the moulding.... You should pull it off the back of the moulding before you put it back on.....It will lay flat after the metal is gone.
Yes, 3m dbl sided moulding tape. the wider the better
Quote from: Mr-Mach1;345036
Thanks
Leon
Consider piano wire to slice the adhesive behind it.
Quote from: Cougars 2 go;345054
I used the welding wire from a mig welder. Same idea, possibly already in your garage. :)
