Topic: PA AOD KICK DOWN CABLE (TV CABLE) 1987-1993 will this fit a 1988 cougar XR7??? (Read 2710 times) previous topic - next topic
I need to know by end of the day to fix my car and save $25 off cjponyparts.com
http://www.cjponyparts.com/aod-kick-down-cable-tv-cable-1987-1993/p/TPC2/
The car keeps sticking in Drive with the AOD and with the supercharger its so not safe to drive at all have to get out and pop the hood everytime it does it.
Also heres a few parts on 50resto would any of these fix my problem???
http://www.latemodelrestoration.com/products/Mustang-AOD-TV-Cables
I can order all of the parts but i need to know what would fix it ASAP and the cable is free shipping at CJ and $25 cheaper. sale ends at the end of the day on AUG 1st.
Right now i am working for a temp place and i need to get it fixed so i can go form job to job BE SAFE.
I hope everyone else is doing good or better than me thanks for looking and any help on this subject if you swapped your TV cable allready or know if it fits and what mods need to be done to make it work right.
Quote from: Carpimp1987;330205
Looks like to me it should work fine. I spent a LOT of time with my AOD modifying the shift linkage so that it would operate my Mark VII auto floor shifter that uses a cable all the way to the shifter which mounts flush to the tranny tunnel without making a huge hole in the top, so this configuration of the transmission kickdown lever is familiar to me since I detached it numerous times to work around it to make my shifter linkage work. I would like to at some point replace the kickdown rod with a cable.
IS the Mustang cable the same length as the Cougars and T-birds???
It should be the same. I bought on of the few remaining (only 3 left in the country!) NOS TV cables for column shifted T-birds and Cougars left in the country last fall. It cost me ~ $100.
