Topic: Changing to 5 speed...... need help on making a checklist (Read 2652 times) previous topic - next topic
Hey guys I have decided that I want the car to go low 11's instead of mid 11's, I figure this will be the easiest way(since I need a new tranny anyway) to get the #'s I want. Now I need help making a checklist on what is needed to make this change. So far my list consists of:
1. pedal assembly
2. cluch cable & adjuster
3. clutch
4. flywheel
5. transmission
6. shifter
7. shifter trim & boot
8. bell housing
9. yoke if different
10. reverse & neutral saftey switch
What else can you guys think of. also if anyone has any of these parts please let me know like shifter trim and or pedals, mostly factory parts I can't find. thanks for anyones help
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
You're gonna need the little plug for the reverse lights-two wire deal on drivers side of tranny. I'm pretty sure when I did mine the manual flywheel bolts were a different length than the automatic's.
bump, just thought of this, but now I will need a cage under 11.49
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Thought you had one already
Quote from: daminc;325987
nope, not yet!!!!!!!!!:mullet:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Don't forget the pilot bearing!
With your 7,000+ shift points it'll need to be a slick shifting unit, which trans have you decided to go with?
Maybe we could talk Eric into putting a T-5 Conversion Article on CoolCats.net ;)
Quote from: 86T-bird;326054
I was leaning towards the tremec TKO if I can find it at a good price:burnout:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Don't forget the block plate (between the bell and engine block).  Its different for a 5spd car versus an auto.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Quote from: 347Thunder;326124
Do lots of research on selecting a box that'll shift easily above 7k and a clutch that will let it live.
I have no first hand experience in this area, but have looked into it as an option for the Mustang (I run a C4 in that and would really like overdrive).
My understanding is a TKO will need to the gears "face plated" or "pro-shifted" from a place like Liberty Gear, Hanlon Motorsports, or Promotion to shift reliably much above 6,500.  Afterward (from what I have read), they take a deft hand to run on the street, but many people do.
There are T-5's (Astro A5's) out there with heavy duty straight cut gears that can take the abuse and RPM, but really should be strip only (they aren't called "crash" boxes for no good reason!).
Clutches become much more sophisticated when moving a heavy car and lots of RPM.  Getting a little slip dialed helps the launch and keeps from breaking the box and bogging the engine.  They are a wear item, so replacement is expected.
From a cost stand point, it appears a Lentech Strip Terminator w/converter is pretty comparible to a good manual box set up for drag racing w/clutch and blow proof bell.
For me it was daunting enough to stay with the C4... at least for the foreseeable future!
As I mentioned, I'm not an expert or have first hand experience with a manual for drag racing, just my poking around over the past couple years.
For the best souce of information: Speak to the vendors mentioned above.  They each will put together a package to get you set up for your goals.  They'll walk you though the why's and what for's.
Hope you have good luck!
Mark
driveshaft is different, i had to shorten mine 1.5" last night when i did my conversion.
86 Mustang GT
My driveshaft and crossmember swapped right over.Crazy stuff.
So the driveshaft needs to be changed??? As for the crossmember I will just re-fab the one I made
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I had no driveshaft issues with the swap to a T5.  Same as AOD unit.
Quote from: 86T-bird;326313
Same here.
