Topic: How to Test Valve springs (Read 763 times) previous topic - next topic
How Valve springs are checked
I had to check the valve springs for a 4G63T
This is a simple process. But a specialized piece of equipment is needed.
I use a Rimac spring tester with a 300lbs scale.
The first thing to do is set the stop to the correct height.
The spec used is  66lbs @ 1.575
I find that a venier caliper is more accurate than the built in scale.
Place the spring to be tested in the spring tester
  Compress the spring to the pre set height and read the pressure.
It is a quick and simple way to have your valve springs checked to make sure they are in good serviceable shape.
Low spring tensions can lead to a lazy rev of your engine and also valve float.
