Topic: 302 H.O. Questions!!! (Read 3462 times) previous topic - next topic
A guy on a local classifieds site has a 302 h.o. out of a 91 cougar and i was wanting the h.o.cam  for my 302 i installed in my 79 cougar a couple weeks ago,,so my question is ,,is that a roller cam or will it work in my motor??? thanks
1979 Mercury Cougar X R 7
White w/ Maroon Vynl Top
Maroon Interior
302 BIG HP IN PROGRESS
All passenger car 5.0/302 from '86-up are roller... Those cams will not work in a std lifter block...
If whatever this said cam is, whatever the cirspoogestances, IS indeed the stock cam from an 80s 5.0 HO, if it is pre-1985, it is not a roller cam, if it is 1985 or newer, it is roller.
it can be done.  to drill the lifter valley and make it a roller block as long as you have all of the required parts to do so.
Quote from: 88turbo;293221
But you still won't have the proper support for the LONGER roller lifters...
Aftermarket cams for std blocks, have a smaller diameter base circle than the factory cams...
he says its not a roller,,it was carbed
Maroon Interior
Quote from: 1979 Cougar XR7;293230
Then it is not a factory 302 HO so you have no way of knowing what cam is in the engine ;)
he said a new cam was put in last year,,he only wants 100 for the whole engine intake to oil pan ,,and it runs  but all i want is the cam,,hes hurtin for money pretty bad
Maroon Interior
Quote from: thunderjet302;293234
Weren't the 85 Mustang 5.0 rollers? You do realize someone could have carbed a 5.0 HO right?
Quote from: 86XR7project;293244
Yes I know but no 91 Cougar ever came factory equiped with a carbed 5.0 HO;)
If he really wants to make the sale, tell him you want to yank a valve cover and measure a push-rod.  That'll tell you if it's a roller cam or not.
Flat tappet 302 push-rods are approximately 6.875" long, while factory roller push-rods are 6.200"...if the engine has an aftermarket roller lifter conversion, they'll be about 6.400" long.
Good luck,
Don
Good advice Don...
Quote from: TurboCoupe50;293280
Good advice Don...
Thanks buddy, a good idea smacks me across the face every now and again...lol.
91-93 cats and birds with the 5.0 supposedly use the 93 cobra spec cam.
Quote from: thunderjet302;293272
There are a few 87-88 5.0 Cougarbirds HERE that are carbed.....Just because something's on a used car when you got it doesn't make it stock ;)
As stated above; ask him what the pushrod length is.
Quote from: Haystack;293343
The Cobra cam has a 1993 part #.  It WAS used in 93 Cougars/Tbirds, but with 1.6 ratio rockers as opposed to the 1.7 ratio rockers in the Mustang Cobra.  '91 & '92 model year Cougars & Tbirds 5.0 cars used the H.O. cam.
