Topic: auto dimming lights (Read 1573 times) previous topic - next topic
auto dimming lights
ok, so I got my 79 f150 running right, finaly.  as soon as I can get a fuel tank for it, (current one leaks above 1/4 tank.) I plan on starting back in on the bird.  I have been tinkering with it though.
Is there a way of troubleshooting the auto lights?  I dont think mine are working at all and was wondering where would be a good place to start.  On another note, would it be possible to take auto dimming lights out of another bird and install them into  my truck?  is it built into a computer, or is it just a basic wiring harness that could be installed into something else with a little work?
I just thought it'd be a cool thing to have that you dont see in other builds.
86 Thunderbird TurboCoupe, 66 289 HI-PO, auto.
Hoof beats may be faster than heartbeats, but birds are faster than ponies!
auto dimming lights
are you talking about the headlight auto dimming? ( from high to low beam when cars come closer)
or the courtesy lights that shut off after you turn the key off?
They both work off sensors and they're own timer/relays.
I do have a trouble shooting guide for them in the tech manual. If I get time I can scan it and post them
auto dimming lights
well, lol  I wasnt aware that it had both, havent had time to mess with the car much.
I was talking about the auto dimming headlights, but now I want both. lol I'll have to mess with it some more. lol  If one doesnt work, would it cancel out the other too?  also, if I'm able to go through with putting it in my truck, I'd love to do both.
sorry about the questions about the truck, but since theyre gonna be Tbird parts,  you see.  also thanks for the help getting them figured out in my bird.
auto dimming lights
Ok, I checked,  the headlights tun on when you flip the switch, but thats it. I rolled the switches all the way up to max.  I shined a trouble light on the light sensor on the dash and it didnt change anything.  I covered up the light sensor on the mirror and they didnt flip to high either.  or should I say, they wouldnt flip to high, even with me trying to operate them  manualy. lol
auto dimming lights
on the other hand, with the autodim off, I could turn my high beams on and off.
auto dimming lights
Quote from: shameless;279540
Is this the main headlight switch?
With the main headlight switch off, the autolamp switch on, the ignition switch in run and no light on the light sensor the lights should turn on.
The thumb wheel for autolamp sets the turn off delay.
The ignition switch must be in run for auto dimmer to work.
The auto dimmer switch must be off for the manual dimmer to work.
auto dimming lights
For auto dimmer to work the brights must be on. If they are not the auto dimmer will not function.
auto dimming lights
so to make it work, make sure its in the high beam position, turn off the main switch, turn the wheel up all the way to max, turn the key on?  Covering the sensor on the dash should turn on the lights, and then covering the sensor on the mirror should switch it from low beam to high beam?
auto dimming lights
Yep. Turn the headlights on with the switch. Turn the brights on. Turn off the headlights with the switch. Cover the sensor on the dash and turn on the auto lamps. Your brights should be on. Turn on auto dim. Shine a light into the sensor on the rear view mirror. Your brights should go off. Remove light and the brights should go back on.
auto dimming lights
ok, tried it, and nothing happened, should I suspect a relay or maybe a fuse?  like I said I can turn on the lights manualy, but the auto doesnt work.
Do the electric eyes have a history of going bad, and if so, can they be replaced without a lot of hardship or money involved?
Thanks guys, I know its kind of a trivial thing at this point in my project, but to me thats one of the coolest options that came with these cars.
auto dimming lights
Check the fuse and the wiring behind the headlight switch. Do you have a fuse diagram? There should be one on the inside of the glove box door. If not let me know and I can scan the one from the owner's manual.
auto dimming lights
If it is a fuse problem it will be fuse 18.
auto dimming lights
well, I need to go through and check every fuse, didnt someone say there were also relays in these cars for this, I'm sure the fuse would be the first guess but I'm just curious.
