Topic: H.O. cam (Read 1151 times) previous topic - next topic
H.O. cam
Can a H.O. cam use flat tappet lifters?
Only in America do we use the word "politics" to describe the process so well: "POLI" in latin meaning "many", "TICS" meaning "bloodsucking creatures".
H.O. cam
If it's an '82-'84 yes.....
H.O. cam
If it's a roller block why would you want to?
H.O. cam
Not on a roller cam, they are made of steel and will eat the lifters within a couple hundred miles...
H.O. cam
Tom, while they're supposedly a stronger metal, the Ford roller cams are still SADI cores.
DI = Ductile IRON
H.O. cam
Quote from: Kitz Kat;257288
A guy I work with has a '85 fairmont with a 302 and curiously a 3 speed manual. He wants to use a roller cam in his non-roller block but has the flat tappets.
H.O. cam
Go with roller lifters.Does the block have the bosses to drill and tap the holes for the lifter retainer?If so,easy stuff.
H.O. cam
Quote from: vinnietbird;257337
I couldn't tell you. I'm just going to tell him to get a crane cam or something. :disappoin
