Topic: Well, that was a disappointment... (Read 4051 times) previous topic - next topic
Quote from: EricCoolCats;253019
If the motor is out of the car...it's sure easy and inexpensive enough to take the block to a machine shop and have some reliefs fly-cut into the pistons. ;)
The engine I'm using is in the car. The one I took apart is out, but it's so worn out it's not worth doing. Like I said, I will hang onto the other one and someday rebuild it proper (including a bore and new pistons)
Quote from: Kitz Kat;253021
Sure sounds like someone put a 86 block in it and used the e-7's.
I think all the ho cams are pretty close to being the same it may be hard to tell the difference. I got some spec sheats I can check but I don't think it will help.
I wish that were the case, because I'd at least be able to use the heads. This engine has E6's on it.
Quote from: dominator;253028
What a mess,i wouldn't trust that you have an HO cam thier either.
The injectors should be orange top for stock HO(i have a set of 8 that i took out of my HO) tans are stock SO.
You've got an SO that someone played around with,is it even a roller block???
If it is it's .
I have a 91 HO cam and a set of orange tops i can let ya have for 60.00cdn shipped if your interested(They came out of the 91 HO i put in my TC).
According to Coolcats the 19-pound injectors can be either orange or tan, while the SO injectors are light grey. I confirmed that my 88's SO has light grey (almost white) injectors on it, and the ones on the other engine are definitely tan. Strangely, I can't seem to find any mention of tan injectors doing a Google search. Time to go pull one out. As for the cam, it is the HO firing order, so I must assume it's an HO cam of some sort (or, knowing how ized this engine is, a 351 truck cam)
I might yet take you up on that offer, depending on whether I can figure out what I've got here.
Quote from: Thunder Chicken;253038
The 35# injectors in the '85 and newer 2.3L Turbo's are tan.
Here is the color breakdown in the 5.0L Technical Reference book.
14# - Gray - Non-H.O.
19# - Yellowish-orange - H.O.
24# - Light Blue - '93-'95 Mustang Cobra
30# - Red - Early 2.3L Turbo
35# - Brown - Late 2.3L Turbo
Can you tell if the pistons are cast or forged?
One of 1,246 built
If it's a '86 HO, it should have E6ZExxxx on the piston tops... At least mine does...
Tan or orange, one in the same 19lb(I believe they change color with heat)... The white/light gray are the 14lb, all SO 5.0, NA 2.3 and std 3.0 used these inj(no doubt a few others)...
Quote from: BCA;253040
Nope, [COLOR="Red"]Red[/COLOR] inj are 30 lb, but were used in the '89-'93 3.8SC engine, plus are high impedance vs the low impedance 30lb [color="green"]Green[/COLOR] inj that were used in the early Turbo Coupes(and SVOs I believe)...
The '94 & '95 SC used a 36lb dark blue high impedance injector injector, not interchangeable with the TC browns...
Quote from: TurboCoupe50;253045
Nope, [COLOR="Red"]Red[/COLOR] inj are 30 lb, but were used in the 3.8SC engine plus are high impedance, vs the low impedance [color="green"]Green[/COLOR] inj that were used in the early Turbo Coupes(and SVOs I believe)...
You are correct; the early 2.3L Turbos did have green injectors I should have realized that when I was typing it.  :punchballs:
One of 1,246 built
OK, back in from the garage. When I unplugged an injector it was immediately obvious they are orange. The exposed area is just faded to look tan. The plug area didn't fade like I guess the exposed area does.
As for the cam: I measured the lift using the very non-scientific method of using my digital caliper's depth rod. I rested the caliper base on a lifter, the depth rod on the dogbone, and zeroed it at 0  lift. I then turned the cam and took my highest reading, which was .24". That's pretty close to the .237 BCA quotes for a non-HO cam. Perplexed that I got the non-HO lift I checked the firing order again, by starting out with the #1 cylinder intake lifter just about to lift and then turning it, watching the order the other intake lifters lifted. I got the same numbers I got before.
I then double checked on Mitchell. That's where my mistake was. I checked the firing order for a 1987 Mustang GT. Figuring that the program would actually give me the firing order of a Mustang GT I assumed my 15426378 was a match. Nope. Mitchell shows a non-HO firing order for the '87. When I checked '89 it gave the different, and apparently HO, firing order of 13726548.
As for the pistons, I have not pulled them out. I stopped disassembling it the moment I realized it was basically the same engine I already have in the car (and given the ridges, I'd probably need a ridge reemer to get 'em out anyway). From what I can see they are perfectly flat except a very subtle dish in the center. I can't tell if they're forged or not, but given the non-HO cam and E6 heads I'd say it's a safe bet they're not.
Final verdict: I've got a non-HO 5.0 with HO intakes and injectors. Oh well, like I said, the engine was pretty much a freebie. I'm glad I decided to take it apart before installing it :hick:
Looks like I'll be needing a cam and some heads.
Quote from: Thunder Chicken;253049
That's a SO piston, '86 HOs have no dish at all, perfectly flat...
Quote from: TurboCoupe50;253050
And forged.
Well atleast you have a spare engine to build later :hick:
The worst thing is I just three days ago sold my 351 for the money to do this thing. With the E7 heads :hick:
And to add insult to injury, THIS shows up for sale locally. A bargain, but out of my reach at the moment. Unless one of you guys wants to lend me $850 :deal: PLEASE!!! I'll be your friend!
Dam i need those heads,the rpm's would go perfect with my vortech.
My performers are a little small but still function very well.
850cdn is a killer deal for those,they'd be to much on a stock HO though,my performers would be better suited.
Tell you what you buy those and i'll trade ya LOL JK...
Still got that cam,in mint shape from a 100k HO.
I'll let you know on the cam, I'm trying to track down heads right now.
Those RPM's are nice, aren't they? I know they'd be too big for a stock 5.0, but then again, with those heads it wouldn't be stock ;) If I could afford those I could afford a 347 bottom end and a decent intake/cam :hick:
Quote from: Thunder Chicken;253089
On the contrary, they'd be fine on a 5.0... Your problem would be valve clearance on the SO pistons...
Quote from: Thunder Chicken;253062
HEY Thunder Chicken
 i don't know if this helps you but i have extra set of E7 you can have .if you pay  the shipping!
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
