Topic: well i aligned my 86 tbird today with the sn95 spindales (Read 2224 times) previous topic - next topic
well the camber is still postive but its in the green but still postive i didnt check caster cause i have no adjustments but any way the toe is dead on ive checked and took it back and redone and it still dont go straight it dont pull or anything but ive gotta hold the wheel to the right to go straight any ideas guys or am i gonna have to get camber caster plates from mm any advice wanted
Robert
You can slot the top hole on your strut where the spindle bolts slot it back and it. Will let you pick up some negative camber not a lot but some
well i need caster adjustment
Robert
Sorry your post tals about camber not caster
Funny! I read it as "caster" even though it says camber in the second sentence.
Quote from: Cougar5.0;249938
That's funny...I couldn't read the run-on sentence whatsoever..
If you have to hold the wheel then you have a pull.
Try cross rotating the front tires.
If your alignment angles are in the green then it's a tire pull.
My sc's alignment is 100% in the green front and rear, with the summers on she's straight as an arrow.
When i put my winters on she pulls hard right,cross rotate fixed that.
Well I didn't check caster but I'll try swapping them and see what happens
Robert
try these
http://cgi.ebay.com/ebaymotors/FAIRMONT-GRANADA-LTD-MUSTANG-THUNDERBIRD-CAMBER-KIT-16M_W0QQitemZ220303342897QQihZ012QQcategoryZ33581QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
these will help on camber adjustment on fox bodys car
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
Quote from: FordTruckFreeek;249951
I'm so used to reading poor english that I also subliminally added the period where it should have been - doh!!
Quote from: rancheronut
try these
http://cgi.ebay.com/ebaymotors/FAIRM...QQcmdZViewItem
Are those offset A-Arm mounting bolts?
well upon further investigation it looks like from reading in my old school books that a vehicle will pull to the highest positive camber so i orded caster camber plates and hopefully that will take care of it
Robert
Quote from: 1trickbird;249909
You can pick up A LOT going that route.
This was one of the old school tricks of the slalom/road race guys with Fox based cars (and many others) I did it to my struts when I was running open lapping events on a regular basis. Stock max I could get was -1*
After the mod I could easily get more than -2.5*. Remember....an 1/8" at the mounting point translates into a much larger move at the top of the tire.
