Topic: vacuum lines ?? (Read 1114 times) previous topic - next topic
vacuum lines ??
Just out of curriosity,, does anyone know where to get new engine bay vac lines?? ya know , the kinda platic ones. The one to my FPR went south ( i used reg vac hose for now) and i thought about replacing them all (at least some) with new ones.
Thanks, Joe
vacuum lines ??
Any truck shop should have them,There used all over on air brake systems.
vacuum lines ??
When they break I just replace them with rubber line from the parts store. Works the same ;)
vacuum lines ??
Ditto, what thunderjet said
vacuum lines ??
Quote from: kitzdnm;235668
oh really?  in this size,,and various colors?  I cant see a truck having use for this small of a line.
vacuum lines ??
Quote from: thunderjet302;235687
that's what i used, i just thought if the hard lines were easy to get a hold of i would like to put them back on
vacuum lines ??
Quote from: jcassity;235797
They use them from 3/32 to 5/8,The smaller ones are used behind the dash and the transmission,and they come in blue,red black and green.
