Topic: EGR deleate (Read 3423 times) previous topic - next topic
EGR deleate
Me and a buddy were thinking bout taking to EGR vavle of our cars he has a 83 Mustang Gt but it doesn't have OBD1 if I do this will it throw a code if I do the EGR valve deleate I know on OBD2 it will but on OBD1 will it.
EGR deleate
yes, it will unless you have a tuner turn it off through a chip.
1979 Ford Fairmont
[/B]
EGR deleate
Not sure about a 2.3 ECU, but the product listed on the website below will work for EGR bypass on a 5.0 ECU.  I would guess the electrical stuff can be used for the ECU.
http://rjminjectiontech.com/?p=9
EGR deleate
The 2.3L cars always throw an "Insufficient EGR flow" code due to the restricter  they put in the line during the recall. That's the only code you will get.
EGR deleate
AFAIK if you remove the EGR it will throw a code but the EEC will compensate for that by removing the EGR function from it's calculations for fuel and spark resulting in no loss of drive-ability. It will throw a code but run fine. This is according to Joel5.0 on sbftech.com
EGR deleate
Excuse me if I'm wrong-but aren't 83 mustang gt's carbed with no computer?
EGR deleate
My EGR is deleted
Check engine light on thoughing code that’s it
Engine runs fine
EGR deleate
So what's it hurting??? I may run a off road pipe, but the EGR still functions...
EGR deleate
The EGR is the only emissions component left on my T-bird. It helps with part throttle fuel economy and doesn't hurt performance so I left it on. It's off at WOT so it's not hurting anything. Really I don't know why someone would want to disconect it....
EGR deleate
Thanks guys. The mustang still has a code devise its the one before OBD what ever that is.
EGR deleate
Quote from: V8Demon;234607
Is that site the top dog of wiring harnesses ?  I never knew all the little issues with different companies until i read through all that.  You recommend these products?
EGR deleate
It ain't nuthin' but a resistor... Value I dunno...
EGR deleate
Quote from: TurboCoupe50;234687
yeah, thats what i was thinking,, they are calling out .5vdc,,, so whatever the EVP reads in its rest position would be the resistor size.
EGR deleate
Quote from: jcassity;234695
Would be easy enough to measure... If I remember correctly, the total resistance for the sensor is 4.5K ohms...
If all this is true, could just plug the vac to the sensor to test... I'm thinking it will set off the CEL, once engine is up to temp and cursing at speed...
EGR deleate
double post
