Topic: Average Miles per gallon (Read 3603 times) previous topic - next topic
What’s average mileage for a 4, 6, & 8 cylinder thunderbird? My daily driver is an 8 cylinder and reaching the end of its life and I was thinking of replacing it with a 4-cylinder turbo.
What do you think
Re: Average Miles per gallon
Well, I'm getting upwards of 500km (310miles) to a tank in my TC. If that helps. And that's city driving.
Here's actual owner-observed economy and other stats taken from a 1987 Motor Trend owner's survey:
http://www.foxthundercats.com/vitalstatistix.htm
You can squeak 30 mpg out of a 2.3T on the hwy at times.  Around town, they aren't too much better than a 5.0...mainly because it's too easy to put your foot into it. ;)
What's the daily driver?
like chuck said i get on avg 27mpg hwy and 18mpg cty but i have a heavy foot in town out of my 85 XR-7
Its a 83 thunderbird. Bought is for $400 3 years ago. It has the 5.0 out of my first blue t-bird that got rear ended. Its right around the 150,000 mark wich seems to be when the seals in these engines start needing replacing. Its got the throttle body injection. It works but I dont think its the most efficient. I was also thinking maybe a carb set up might even be better milage wise than the throttle body set up. I just thinking about it now so when something really goes wrong I have a plan. Not even sure if a 4 cylinder swap would even be worth it but I seem to use a hell of a lot of gas and with gas prices so high it might be worth my time.
Quote from: Thunder Chicken
On this linked page it says it's a 1997 survey.  Might want to correct that.
1987 Thunderbird 3.8. Sold :(
Andrew, it all depends on the amount of hwy driving you do really.  My Tbird/Cougars get much better mileage all around than my 2.3T Ranger does with the same gearing.  It's the aerodynamic factor..the Ranger isn't and the 83 Tbird is fairly slippery.  I've pulled down as good as 32mpg on the hwy (75-80mph).
My 83 turbo 'bird is an ex 5.0 car.
I get about 20 mpg average (half city and half highway) in my Cougar with 3.8. All highway and I normally get about 25 mpg and all city I can usually get 18 mpg.
I get about 13-15mpg driving all crazy-like in the city, 30 on the fwy
i'm hoping my carb is bad. i average 15 mpg in the city. only a measly 21 hwy. i don't have overdrive, and my torque converter was shot.
Quote from: lowcat
Same thing here on my '87 5.0
Same thing for me, like 21 mpg at highway (V6/no OD) and 15 or less at city, being gently....i´m driving at 55 mph at highway...
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
