Topic: Custom lower radiator core support (Read 2035 times) previous topic - next topic
A few years ago I slid off the road and mangled my core support on a palmetto bush, so 5 years later I decided to fix it LOL. I had my buddy bend 1-5/8 tubbing to my specs and I also decided to lower the radiator so it sits flush with the upper core support for a more finished look. I added some gussets so I can strap my car down when I tow it to the track.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Spiffy.
Umm, you know, palmetto bushes and coyotes do remarkably the same kinda damage.  I centered a coyote on the interstate running 80 mph.  Dunno how, but it didn't harm the radiator or condenser coil.  Rolled the rad support up pretty bad, tho.  I took some large wedges and expanded the collapsed part first, then used a cable winch tied to a tree to pull it back forward where it belonged.  I found these cars are NOT heavy enough to be pulling on the rad support, yet too heavy to depend on it for tow hooks.
:birdsmily:
(X2) '86 Thunderbird, 3.8L CFI, C5 Tranny
'92 F-150, 5.0L EFI (SD), M5OD Tranny, 3.08 Dif
'70 VW Beetle, 1780cc, twin Solex 43's.
all done, now I just need to get new rubber mounts
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
more
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Very nice looking!
Very nice work looks great.
Both of my cars would use that.
Seems like every fox body I own has a damaged lower rad support.
It's Gumby's fault.
pretty nice looking. not so bulky either.
Thanks, I cant believe how strong it is I can jack up the car by it and no flex, might help my 60' time :D  :burnout:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I'm very interested to see how this turns out.  Looks good.
Me too!!!!!!!!!!! LOL
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
