Topic: Autolamp delay Headlight switch 1984 Thunderbird (Read 808 times) previous topic - next topic
I'm looking for a headlight switch with the autolamp delay to fit 1984 thunderbird. It has to be the plunger type switch.The one you pull out and push in to turn on and off. I think the swith will fit from other fords as long as it has autolamp delay.
I also need the power lock solenoid that goes in the door. I need both sides. And maybe the switches as well.
Let me know if you have anything
thanks
I'll check while I'm at those boneyards today.
that would be greatly appreciated. I can't find a switch around here anywhere. I can get a new one off the internet but I need the Plunger part as well
No dice.Not a single one out there.Sorry.I'll keep looking.If you find one first,let me know.
get the switch at the parts store you don't wanna get a used switch. also at the parts store they should have that plunger part too. the plunger will be in the help section.  the borg warner part number for the headlight switch with auto lamp is S2097 i know you can still get them my local parts store has one in stock right now
