Topic: CHE Suspension (Read 3636 times) previous topic - next topic
CHE Suspension
I am looking at some rear suspension parts from CHE. Before I buy, just wanted to check and see if there were any negatives with them... Dbl Adjustable uppers and non adjustable lowers are the parts. Thanks for the heads up...
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
CHE Suspension
just got mine yesterday .very high quality .i bought the  upper and lower set . and dont forget to use the coolcats discount .i saved over $40.00 on my order
CHE Suspension
Awesome,buy em you'll be happy.
CHE Suspension
Put mine on couple weekends ago.work great. like said use the COOLCATS discount.the only thing you dont get is the upper Polyurethane bushing for the rear.It can be had at http://suspensionparts.com/ seperatly.
CHE Suspension
Kewl, thanks for the input I will prob order tonight..
CHE Suspension
Quote from: BEARMAX;208320
What is this you speak of
CHE Suspension
Quote from: cougar86_89;209710
On there sight when you check out you put COOLCATS in the promotion .
CHE Suspension
I run / tran the CHE stuff in my T-bird (they are now under Frank's 83) becuase it was what waas available for the T-bird. I love their stuff so much, I bought it for my Capri too, even considering I had maybe 100 choices there. That should say something about how I like their stuff.
Quote from: kitzdnm;208344
I do not like the idea of the poly bushing on the housing end. Its adds too much bind. If anything you can add the sperical bearing there, but I have always got along fine with stock, or ford replacement bushings on the housing end.
CHE rear eye candy ;)
Bob Myers
CHE Suspension
I wasn't aware of the bind that poly bushings cause.  thats what I ordered.. I still haven't received mine yet but I guess they will be here early next week.
CHE Suspension
I believe he means the one that doesn't come with it for the upper rear,the others will work fine.I didn't order the extra one,I just used the stock one on the rear.I just put that there in case someone wanted all poly bushings.You should be fine.
CHE Suspension
No, the extra one I ordered was for the upper control arms that goes in the 8.8. The stock ones are shot. When I get done with replacing all the bushings this thing should feel like a caddy. Maybe it won't squeek anymore either!
CHE Suspension
Got the CHE parts in. They look good. Of course any parts are going to look better than what is under there now. Should ride much better now.
CHE Suspension
just got mine
im going home early
Bushings and 2001 bullit suspension
Do you guys know if there is a complete bushing kit available out there    and anyone tried the 2001 bullit mustang springs and shocks:birdsmily:
CHE Suspension
Quote from: 1986Élan;217492
Yes. Search function.
