Topic: 3.8 to 351w con (Read 803 times) previous topic - next topic
3.8 to 351w con
dropping a 351w in 87 bird with a 3.8 how hard will it be and what needs changed for it to fit
3.8 to 351w con
ok first you need the fox double sump oil pan ..and v8 moter mounts...are you runing a carb or fuel injection if a carb than u need to remove the fuel pump from the tank and run new feul lines all the way  back  also run a ruber line in the pick up hanger where the pump use to be to the botom of the tank  now you need a in line pump i use the holly pump ...very good pump ...mount it  in front of the rear end at the tank works great ...i also had to run a wire to my alt becuse i ran the original v belt set up ...but that is going to change here soon with the serp conversion ....also the auto tranny sucks ...you need the 5 speed ...unless you are going fuelinjected if so than i cant help you with all the details...good luck ..any mor qust just ask
3.8 to 351w con
ok kool what a about a posi rear end
