Topic: block id (Read 1187 times) previous topic - next topic
block id
does anyone know d9ae 6015 ed 20    9a29?? help think is a 351w
block id
A D9 block is '79
Measure the main bearings, the 351 is 3", the 302 is 2.25"...
block id
the 351W is 2" wider then a 302 at the heads
It will also be stamped 351W in the valley
block id
January 29th, 1979.  6015 is a basic block casting number.  You will likely need to visually ID it by what was already said.  A crankshaft will have something like 3M stamped on it, a 302 will have 2M stamped on it.
1987 TC
