Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1517872 times) previous topic - next topic
Reply #2490
Whether it's bending lines or bolting the engine together,it doesn't matter. Progress is progress.
Reply #2491
Oh well, no brake lines today. I worked, then had to cut the grass, and close the pool for the year. Tomorrows another day. I thought about working on it for 2 hrs while I was cutting the grass. Does that count for anything. lol
Reply #2492
almost done with the motor...
Reply #2493
Quote from: daminc;335995
this REALLY makes me miss my cougar
Reply #2494
Very Nice Jeddy !!! That will look great in the Cougar's engine bay.I'm proud for you. Be cautious about the black a/c bracket.They have been known to make ugly contact with the TC hood scoop.I left mine off with no problems what so ever. I've also seen people remove some of the metal from the top of the bracket. Hopefully you won't have any issues,but,just something to watch for. I am surprised you didn't go with a 3G alternator.
Reply #2495
Your keeping the air pump on? Looking good Jerry. Like Vinnie said watch that ac bracket it will hit especially with chucks's mounts,I shaved the top of mine down.
Reply #2496
Well, the bracket is on for now. I'll see what happens as I go.
What do I need a 3g for?
Kitz, the air pump goes nowhere
Reply #2497
if your tie rod ends are really floppy or easy to move, adjust the inners now.
there are two types of inner knuckles in  coupld different way.
one type goes like this....
loosen dust cover clamp and slide dust cover outward
locate allen set screw on the outside of inner knuckle and loosen
remove knuckle from rack by using a cresent
look inside knuckle and there will be a small hole in the center
inspect hole and if its hex shaped, then find an allen to fit it.
Rotate allen wrench ccw a few turns
this means you are rotatinga disc in the inside of the knuckle
remove allen wrench and then inject grease up into the ball joint
through the allen hole.
rotate inner ajustment disc until your ball joint now is snuggly
attach assembly back on rack/pinion until snug only
tighten allen screw down to lock it in place.
get alignment after both sides done.
the other type goes like this.......
get dust cover slipped off and to the side
locate what appears to be an allen screw, discover its actually a hammered in roll pin.
get a screw to thread into the roll pin then slap hammer it out
remove inner tie rod from rack
look into the knuckle of the inner tie rod and discover a plastic disc in the center with a tiny hole.
if disc in the center is a plastic one then add grease inside knuckle
install inner tie rod and the grease will purge through the hole and out into the knuckle.
keep tightening the inner until the knuckle doesnt flop around too easy but is snug.
add a new roll pin to the outside of the nuckle locking it in place.
the only reason i posted this is because the rack is a pita if you dont repair or do some pm while its out.
also,
for the future, you can lob off part of the control arm pan head portion of the bolt so it can be easily taken out later.
see what i did in the pic below.
Reply #2498
all the front end parts were new the year I took the car off the road. I just replaced the lines on the rack last week, so everything should almost be new in the front now.
Reply #2499
The 3G is a great alternator. The stock one barely can handle the load.With the 3G,I can have the heater on,all of the lights (and fog lights) stereo,defroster,and no dimming head lights at all.Plenty of juice when the car needs it.It's a 30 minute to an hour job from start to finish.One of those " I wish I'd done this years ago" kind of jobs.
Reply #2500
there's no way I'll ever have all that stuff running at once. I'll probably never drive it at night anyway anymore. the defroster will probably never be turned on again either. lol I have used the lights 2x on the vert so far, only because they have to turn them on to inspect it. lol... My power needs are simple nowadays.
Reply #2501
Not to mention the risk of fire with the 2G is eliminated, but it is not a necessary upgrade .:D
Reply #2502
Quote from: hypostang;336784
LOL, if I was worried about fire, I would have replaced my ignition switch years ago... It's still all original.. :D
Reply #2503
Quote from: daminc;336788
lol, if i was worried about fire, i would have replaced my ignition switch years ago... It's still all original.. :d
 doh !!!!!
Reply #2504
Quote from: daminc;336777
Well,then you're good.LOL. I think I still have my new 2G in the garage somewhere from when I did my 3G upgrade.
