Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1489370 times) previous topic - next topic
Reply #1785
The spider hold down in the valley is the #1 indicator along with the "XXX" stamping.
That appears to be the original block to the car.  The lifter dogbones are a dead giveaway as well.
Looks like you got yourself two boat anchor E6 heads as well.  :hick:
Reply #1786
I read somewhere that the xxx is the location where they were manufactured, as some people said they had non-roller blocks and the xxx on it. YYY blocks were said to be manufactured in Mexico with a higher iron content compared to the XXX blocks. I don't know if there's any real truth to that though. I'm going to keep searching for the real answer, be it location, or block type. I notice there's a lot of bad information out there about Mustangs, motors and modding. It's tough to know what to believe sometimes.
Does anyone have a pic of a non-roller motor? It would go good in this section of the project thread, as a comparison of the 2
Reply #1787
Quote from: V8Demon;305281
I was just looking for a door stop too.
Reply #1788
Left is a roller lifter - which makes it a roller block.
Right is a flat tappet lifter - which would make it a non-roller block.
X
Roller blocks typically have the top of the lifter bores machined flat for the dogbones to sit.  The dogbones and the spider keep the roller lifters in alignment with the cam.
Reply #1789
Does anyone have a pic of the non-roller block?
Reply #1790
Quote from: daminc;305300
Not on hand with an intake off, but like said the the dog bones are on it ,that makes it a roller. There would be less lifter bore on a non roller. Just build it, Quit stalling!!
Reply #1791
A quick googling and presto:
X
Reply #1792
Cool, thanks.. I've been googling  that for about 5 days now with no picture results.
.......On with the project.
Reply #1793
Good it's a roller. Just bore it .030 over, stick some good pistons in, and you'll be good to go:D
Reply #1794
You need this.Sell the rest.
http://www.foxtbirdcougarforums.com/showthread.php?t=26107
Reply #1795
Update
I've been degunking the motor.. That's all I got
I tried to get a pic of the crosshatch in the cylinders. but my camera really sucks.
Reply #1796
You know what, they all seem to have that regardless of the mileage,don't know why.
Reply #1797
I would imagine they would be the same as the big three cylinder air compressure motors from locomotives I used to tear down. But I think the cross hatching is a factory marking from them being machined. I know if a cylinder had it it was still in good shape. But if it was worn off it usually ment the piston or ring detoriated and sed them off. So I would think you'd want to see that on them. I'm not a mechanic or a machinist but I kinda learned that from experience.
Reply #1798
Looks fit for another 100,000 miles to me ;)
Reply #1799
Looks good !!!
