Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1517020 times) previous topic - next topic
Reply #1110
Quote from: Haystack;264163
So when do we get an update? I need a fix...
OK...
 I actually coated the inside of the old frame with zero-rust so I can weld the new parts on...... Mmmmm maybe some pics and welding tomorrow, I'll se what the day is like.
I was building a media room in my basp00get this week. :D
Reply #1111
Quote from: Chooglin;263671
Daminc,I hope you dont mind me using one of your pics.
I would like to know what the purpose of this vacuum ball is for,Is it a resivior? and can it be removed without any issues?
also ties in the hvav. Trace out the tiny black vac line that penetrates the fire wall near the heater core and you find this little hose also leads to the vac ball thing a ma bob.  I would think it helps move the various flaps and doors inside your dash when you select various hvac / blower directions.
Reply #1112
Quote from: jcassity;264207
Sorry to continue the derailment Daminc, but I figure I'll set this strait.  Its sole purpose is to keep the blower position door in the driver specified location in low vacuum situations.  It has a check valve that isolates it and the blower door actuator from the rest of the vacuum lines during low vacuum situations.  If this reservoir is removed your blower door will move from any selection (floor, vent) to defrost when you enter a low vac situation, I.E. full throttle or climbing a steep grade.  ATC cars don't have the resevour as the blower door is electronically controlled.
Looking good Daminc, are you on AVSforums yet?
Reply #1113
Quote from: CougarSE;264331
I'm really not into all that stuff. I used to be, but the older I get, the less effort i want to put into watching tv. I just need a large tv to watch. and a place to keep it.;)
Reply #1114
Here's some pics guys......
I started the welding.
Reply #1115
Quote from: daminc;264339
You need to put it in the garage, then you can work and play!
Reply #1116
More welding
Reply #1117
Are you gonna smooth out the engine bay, while you're in there? :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #1118
Quote from: cougarman;264560
Of course i am. I've got this far, what's a little more welding. ;)
Reply #1119
Hey, Jerry are you gonna weld "Done By Dr. D" on there somewhere ? :evilgrin: Great Job man :headbang:
Reply #1120
Quote from: mercury-man;264607
That is a cool idea! Since there is so much welding and metal work on the car, it would only be right to weld a personalization on it.
Really makes me want to fit my rust ASAP.
Reply #1121
Quote from: daminc;264605
:D :D :D :bowdown:
Reply #1122
I did  even more welding. Here's what i did in about 3 hrs today.
And here's to show that it's still the same car I've been working on  all this time. :hick:
and it's time for a little paint
I guess it's time to finish one of the last places that need rebuilding. Hopfully I can score a lower rad support to replace mine so I don't have to make one. And then that's it...... Time to do some body work so it can be painted.
next project
Reply #1123
Maybe I missed it, but why does everything look orange?  Is that a rust converter color?  most I've seen is darker red or black.
1987 TC
Reply #1124
Scott, look at the first pic of the first page. That's the color it started. It has no UV protection and it fades pretty fast. It's Eastwood's rust encapulator.
