Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1519672 times) previous topic - next topic
Reply #840
I think the front are a true 11", and require a 15 inch rim. The stock 15" rims came on mustangs, including gt's. The gt's are where we get 11" brakes, so yeah.
I don't think the rears are any bigger then a 10" brake drum, so I would think it would fit, but I'm not totally sure. I had 10" drums with a 14" rim, but drums don't have calipers.
Reply #841
Survey Says YES
14s fit on a 8.8 with a 1/2" to spare.
Reply #842
I thought they might but wasn't sure.
Reply #843
14's won't fit on a lincoln mark vii rear.  I know that from experience.
:pics-stfu:
 Project Thread with pics
Reply #844
Aren't they 5 lug to start with?
Reply #845
The 84-90 Mark VII uses much larger brakes in the rear.
It's Gumby's fault.
Reply #846
Just doing a little more painting.
Did a bunch of pounding on the dust shields to make them look normal again. They were pretty mangled
I'll probably get to put a 2nd coat of paint on everything tomorrow.
And mabe install the battle boxes if things go good.
Reply #847
Sorry, they were that way. They look good now!
Reply #848
Quote from: Kitz Kat;255581
Wasn't worried about them, there's no way to put that thing down, and not mangle them without taking them off anyway.
Those shields are built for a tank. never seen anything so thick before.
I'm also kinda digging the 2 tone paint. I wasn't sure about it when I did it.
Reply #849
It will look good under the car with all the new parts.
I was happy when mine went in.
Reply #850
Battle box time
BTW.... they suck to put in
this is where the hole should be
so I had to add a little
then painted them
While those were drying, I had to do a little modifying on these
Then had 1 hell of a time installing them
Here's where the new hole is now
This was before the new hole was drilled
Here's an inside view of the backing plates
I don't recommend installing these unless you can do some modifying and welding
Reply #851
you can bend brakeline with your hands man. those tools are garbage. flaring tools are good, but the  bending tools are junk... I'd rather use a bix end wrench and my hands :D
Reply #852
where were those bought from?
1987 TC
Reply #853
They're wild rides Battle boxes.. for a mustang
I battled all day with those  things.
I guess it could have been worse.
Reply #854
Could you say we'd be better off making our own instead?
1987 TC
