Topic: What Do I Do First (Read 1393 times) previous topic - next topic
What Do I Do First
ok so i now have  my own fox after  seeing the love for these cars from my husband for many years now it never really hit me untill i attended cat jam since then i have wanted my own even though bear has his 2 cats i wanted something diffrent well he finnally brought my dream home with him last night ..i couldnt belive it at first i thought it was another junker he bought for parts but when he unloaded it off his tow truck and drove it in the yard he got out tossed me the keys and said merry christmas and welcome to family.and its a turbo coupe with a stick shift ...o my god i love it ...but that paint has to go ..any way he hasnt messed around with these 4 cyl much so its a learning experiance for both of us ..what performace upgrade should we do first .i like the sound that a blow off valve makes how do we install one .i think that's what he called it ...later guys
What Do I Do First
Open up the exhaust and intake first. Engine bolt on are only as good as the car can breath.
What Do I Do First
You'll see the biggest gain for the lowest cost with a T3 turbo and a Gillis Boost Valve.  If you stay with the IHI, you still need a Gillis Boost Valve.  It works wonders.
What Do I Do First
The first thing you should do is a good tune up and a new fuel filter.  These things can get finicky under boost, and any minor issues with the ignition or fuel system will only get amplified.
Use Autolite, MotorCraft or NGK plugs.  No iridium or platinums.  Use Motorcraft plug wires (they are cheap, easily available and are known for less "issues")
As far as performance goes, the exhaust should be the very first thing.  It's amazing the difference a 3" downpipe and 3" single (or 2-1/2" dual if you just HAVE to have duals) will do for these.
A manual boost controller will be good after that to up the boost a touch, but the IHI turbo on the car now is really only "good" up to about 18# boost, after that you're just heating the air w/o much gain.  Swapping to the Garrett T3 turbo found on the rest of the turbofords will be a minor  "upgrade", but would be a cheap way to up the power.
BOVs sound "cool", but on a stock system they are really not "needed"  and can cause minor issues with the air metering as they vent metered air during shifts and can cause a temp rich condition.  For a stock setup stick with a BPV (ByPass valve) that recirculates the vented air back into the system.  While not as "cool", they are far more practical.
What Do I Do First
Paint. ;)
What Do I Do First
Quote from: thunderjet302;192732
Paint. ;)
Right...tell Bear he's cut off until that car..ain't so choked-smurf blue, lol
What Do I Do First
save for a 5.0 swap j/k
exhaust would be #1 on the list for me along with a boost controller
What Do I Do First
After a tune-up I would do 3-inch Exhaust, K&N Mounted on VAM, Gillis Boost Controller (18#) and have a Walbro on stand-by. The Forge BPVs (or at least the one I had) aren't all that quiet.
What Do I Do First
+1 on paint.  If anything else, slap some pinstriping on there so it don't look so blue.  I'm not a turbo guy, so that's all I can add, lol.
1987 TC
What Do I Do First
Fuel pump. Do it now, and never worry about it again.
