Topic: Is there a way to rig this fitting? (Read 842 times) previous topic - next topic
I removed the heater core pipes on the Cougar and within doing that I have no temp sensor which = no gauge reading...
I'm hearing bubbling in the radiator which I think is because of air in the cooling system which I have been working out, but I need my temp sensor.
Does anyone know what size adapter fitting i need to fit the temp sensor into the port for the heater core pipes?
Nevermind, I went and got a fitting from Home Depot.
Well,that was easy enough.
:shakeass: I know:hick:
I just went and got a 3/8" to 1/2" brass fitting and viola, no leak and temperature sensor works.
I was worried though, I had her running and noticed alot of water on the driveway.
Started peeking under the hood, only to realise that the throttle body warming lines (w/e its called) still had water running through, the heater core side had been discarded, but the other end was just laying down the side of the tranny spewing out water:flame:
