Topic: Brake fluid question. (Read 5059 times) previous topic - next topic
Re: Brake fluid question.
Maybe he's thinking of the old wives tale of using pen 15e or some other sugary soda on clutch plates and brake shoes if they're worn to make them temporarily "sticky".
Mt. Dew will also freeze.
John is on drugs people....
Friends dont let friends use mt dew in there brakes....
watch out what kind of brake fluid you use as it may contain silicone
(some dot4 fluids)
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Quote from: blownbirds
(some dot4 fluids)
No DOT 4 brake fluid contains silicone, only DOT 5.
