Topic: 0-60 mph run (Read 2826 times) previous topic - next topic
0-60 mph run
what do you think it'll do in the 1/4?
1979 Ford Fairmont
[/B]
0-60 mph run
Aw mannnnnn I gots to save my pennnies I want my 3.73s so I can do that too!!!
Awesome. Sounds like youre enjoyin it plenty!
0-60 mph run
Quote from: 32VFoxBird;180957
My guess is about a 14.8-14.9 at about 95 or so. The car starts to loose power above 4,500 rpms because if the stock HO intake (heads and cam are good to ~5,400 rpm). Over the winter I'm installing the GT40 intake I have and a 65mm TB. Once the car comes out in the spring I'm also going to have the exhaust aft of the H-pipe upped to 2.5". That should hopefully knock about .4-.5 of a second off the 1/4 mile time (I think I'm being a bit optimistic on that though). I'm trying to get to a track before they close for the season but the closest one I can run at on the weekends is almost 2 hours away. I keep getting assignments at school that take up my Sundays. Stupid college:hick:
Quote from: ZondaC12;180974
You can't turn the tires over now with the 3.08 Traction-Lok? The old SO and the stock 2.73 open would spin the tires :hick:
0-60 mph run
Mine I guess arouns 10-15 seconds with my V6 232ci, but I'll chech when I able...
I'll guess very slow..
My Mercyry cyclone was around 2.8to 3 seconds YEAHHHHHHHHHHH!...
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
0-60 mph run
um you call that spinning? that is just chirpping, your not lossing any real amount of time with that.  hell my stock XR-7 turns them harder then that.
0-60 mph run
Quote from: thunderjet302;181010
Well its a 2.73 TL. But close enough! Yes if I bury it it will spin em alright and did when it was stock too! But in the videos ur just goosin' it and theyre squeaking!
But its not so much that its the low end off the line jump I want
0-60 mph run
Quote from: 1WLD BRD;181283
I'm not mashing the throttle form a stop;)  I'm trying to get to the point where they just chirp/spin a little and then nail it. What I should do is get a vid of a full throttle launch. Then you can hear my problem. Torque starts comming on strong about 2,200 rpms. The stock converter stalls at about 1,800-1,900 rpms. I'm not shocking the tires at less than full throttle so they just spin a little. I'm a bit affraid to go with a 2,400 rpm stall as I'm afriad I'll have bad traction problems (or not:hick: ).
