Topic: boost fluctuation? (Read 802 times) previous topic - next topic
boost fluctuation?
when accelerating to highway speed my boost fluctuates from 18psi to 10 back to 18 and so on.  I am running an adjustable actuator only.  do I need to adjust it alittle to hold the wastegate closed more tightly?
boost fluctuation?
check you're hoses for any kinks. mine did that had to reroute the hoses.
louie  :birdsmily:
My famous last words:
boost fluctuation?
Tighten it more tightly, and use a manual boost controller.
boost fluctuation?
I'll see what I can do with it when it cools down a bit more.  will keep you posted and thanks again shawn
